Unistream Public IP Address
Buddy123
I fired up a UniStream to see if DHCP was an option - it is not.  The IP address of the panel (which does the heavy lifting) is set in the project definition.
If you want to see the panel IP value, look in under System->General->Panel IP Address.  Then I tried to access this variable and put it on the screen and found it is not part of the System Data struct.  I got the same result when I tried to access it via the ladder editor.  So it's there, but we can't seem to access it.
I think you are out of luck.  I would ask this question officially by sending a request to support@unitronics.com.  Let us know what you find.
Hi;
Under Screens,  Numeric Elements, there are 2   IP Address  Options
            IP Address Edit   -- you can select which IP Address to  view and edit   ( IP Address Type)
           IP Settings Edit  --   Panel, CPU, DNS  -- View and edit
These are all editable from the screen
   In the Ladder  - Strings   --  IP to String    and        String to IP    ( no info in Help for explanations)
       IP to String       allows an  ASCII   Variable
     ASCII to String  -- does not allow setting a Panel IP  -- from what I can see.
    ( Don't have  UniStream to play with  right now  - else I would test them out )
DanT
@DanT - I did see the screen object edit choices but I didn't  think about the IP to string function.  Which is dumb of me because I use that in Vision.  Good thing your brain is engaged!
@Buddy123 -  That made me dig a little deeper into the system variables, and I found my first post to be in error.  I was expecting the IP information to be in the System Data struct, but it's actually in the General struct.  So I need to bone up on UniLogic system names.
Using the system tag "General.Panel IP Address" as a source you can indeed save off the IP address.  I've attached my test project.
7 inch IP test.ulpr
