MVP 2021 kratmel Posted December 6, 2020 MVP 2021 Report Share Posted December 6, 2020 I had to upgrade the control system of the plastic extruder. V700 + V200-18-E46B used in application. The system has been operating successfully for over 2 years. However, a separate installed dosing system that determines the color of the plastic has failed. It has a stepper motor, a driver and a failed control board. I quickly connected the input of the motor driver to the output of the O0 npn PWM and programmed the change of the PWM frequency depending on the speed of the screw of the extruder. Everything worked, but there was one problem. Sometimes the stepper motor must be stopped for a few seconds without stopping the extruder (for cleaning). Accordingly, the stepper motor that started smoothly with the extruder to a certain speed must stop and then accelerate again. And here I find a problem - the output of the PWM which perfectly controls the stepper motor when starting from 0 speed does not want to start smoothly from another source. That is, the variable recorded as the PWM frequency changes smoothly to the setpoint - but the PWM output signal to the stepper motor occurs only after 2-3 seconds and with a frequency that has already reached the required value - respectively, the motor does not start because the frequency is too high. This part of net is controlled by START STOP STEPPER MOTOR BIT. I try to use it for accelerate stepper motor after stop and if it is slower then calculated frequency setpoint ML6. ML11 - PWM frequency, MI61 - frequency change step. I do not know why PWM signal output is paused for a few seconds (i try to disable all other net for test). If MI61=1 - pause is approx 5sec after ML11 reached setpoint, if MI61 = 50 - pause is shorter 1-2sec. If i use MI=200 - pause is short but stepper motor do not start sometimes. I try to see PWM frequency in Info Mode - it is changed correctly but PWM output do not start after PWM frequency variable start to increment. Any ideas for stepper motor start stop controlled via V200-18-E46B PWM output frequency? Quote Link to comment Share on other sites More sharing options...
Isakovic Posted December 7, 2020 Report Share Posted December 7, 2020 In similar project I had some time ago I used HSO in Step Control mode (not PWM), and frequencies for acceleration and deceleration are calculated in linearization block and copied to register for frequency, effectively the same thing you did. I remember having those issues that output would start with high frequency and motor couldn't speed up but can't say for sure what the solution was. When stopping are you ramping the frequency down or just set it to 0? Maybe put a delay after setting run bit if this is allowed. 17 hours ago, kratmel said: And here I find a problem - the output of the PWM which perfectly controls the stepper motor when starting from 0 speed does not want to start smoothly from another source. I'm not sure what you mean by another source. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted December 7, 2020 Author MVP 2021 Report Share Posted December 7, 2020 4 hours ago, Isakovic said: I'm not sure what you mean by another source. PWM frequency ML11 is copy of ML6 - and ML6 is linearisation result depended of ANALOG OUTPUT to extruder. Extruder rump make stepper motor rump from 0 to FmaxPWM. Than this process is slow and maybe i do not find any delay. If i stop stepper (F=0) and restart by increment F --- Stepper motor not follow to fast increment - no signal from PWM output (tested by frequency meter) . After some delay signal start but F is to fast for stepper and it do not start - only rump sound. Than quastion is - how many times per second PWM frequency variable can be updated? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted December 8, 2020 MVP 2021 Report Share Posted December 8, 2020 Kratmel, for your update frequency question I don't know the answer, but it would surely not be the length of time involved here. I doubt that the following suggestion will do anything, but it is perhaps worth trying. What happens if you reconfigure your project to only have ONE reference to ML11, not a few that "over-ride" amounts derived previously in the scan. Do all your calculations on other MLs and then at the end of the project store that result in ML11. What you are observing is perhaps not what the plc is using. Also try quick ramping up and down when you need to stop/start the stepper. cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted December 9, 2020 Author MVP 2021 Report Share Posted December 9, 2020 3 hours ago, Ausman said: ONE reference to ML11 To check where is the problem i test separated solution (no other net present in program) : 1 - extruder-stepper ramping with linearisation (works fine); 2 - time controlled ramp with increment and (or) scan time comtrolled ramp - pause in signal flow start present on PWM output. I need ramp stepper in approx 1-2s from 0 to FpwmMax. I see this ramp in PLC PWMfrequency ML - but no output pause is strange. I dig into Visilogic help and find this: "If values out of range enter the Duty Cycle and Frequency operands, the output turns OFF and remains OFF until the values re-enter the range." I think that V700 + V200-18-E46B is Enhanced Vision, V5xx/V1xxx 0.1Hz to 100kHz But maybe V700 have different frequency range and if Frequency ML is out of range output turns OFF. Then itry to check the same program on V1040... Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted December 9, 2020 MVP 2021 Report Share Posted December 9, 2020 Kratmel, I guess the blank post was deliberate? It is curious what is going on, at this stage I would be doing manual entry of controlling numbers and bits. I also found this piece of info which might be very relevant and needs to be assessed in relation to your control sequencing. Perhaps you need to force a change to a quicker cycle on restart, which will then be over-ridden by the next change derived from your ramping. I know this is saying MIs and you are using MLs, but I would guess the rules are the same. Or perhaps a simple MB controlling bit change will also work. Cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted December 9, 2020 Author MVP 2021 Report Share Posted December 9, 2020 Thank you Aus, I think your assumptions are probably very close to explaining the cause of my problem. Accordingly, I must set a speed limit for updating my variable and not exceed it to get a satisfactory result. Quote Link to comment Share on other sites More sharing options...
