m.ortegar17 Posted April 8, 2021 Report Share Posted April 8, 2021 Good afternoon I have a programming code for the UNITRONICS V130-33-TR20 PLC. In the code I need to implement that: - Normally in I5 they have 24V input - I need that when I stop inputting 24V, it executes the MB16. Thanks! Quote Link to comment Share on other sites More sharing options...
m.ortegar17 Posted April 8, 2021 Author Report Share Posted April 8, 2021 2 minutes ago, m.ortegar17 said: Good afternoon I have a programming code for the UNITRONICS V130-33-TR20 PLC. In the code I need to implement that: - Normally in I5 they have 24V input - I need that when I stop inputting 24V, it executes the MB16. Thanks! attached pic Quote Link to comment Share on other sites More sharing options...
Cam Posted April 8, 2021 Report Share Posted April 8, 2021 Right click on the P in the I5 element and select replace ladder element then select Negative transition element Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 8, 2021 MVP 2021 Report Share Posted April 8, 2021 Is this what you're looking for? You can just right-click on your positive transition contact for I 5, select Replace Ladder Element, and select negative transition. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 8, 2021 MVP 2021 Report Share Posted April 8, 2021 @Camis fast! Quote Link to comment Share on other sites More sharing options...
