Action22 Posted April 10, 2021 Report Share Posted April 10, 2021 Hello, V700 with V200-18-E3XB I am having some issue while trying to auto tune with PID SERVER. I let the autotune run with 2 cycles. by the time it complete i get a "run time error 6 overflow" error and PID server crashes. From what i understand it is a overflow error but I'm not sure how to fixt is within visilogic. Any advice appreciated. I am using a T/C to take temp of water then a PWM output to a solid state relay which would heats up water. Attached is the project that is giving me the error version 4.vlp Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted April 11, 2021 MVP 2021 Report Share Posted April 11, 2021 That's actually a program crash within the PID server. It's been a long time since that module has been updated. What happens if you Auto Tune the loop without it? Joe T. 1 Quote Link to comment Share on other sites More sharing options...
Action22 Posted April 12, 2021 Author Report Share Posted April 12, 2021 It seem like the auto tune never completes when just running from the HMI. The process value will over shoot then drop underneath the set point multiple time (I have to atuotune set to complete after one cycle.) with out the autotune complete bit going high. I was basing most of the ladder logic off this webinar https://www.youtube.com/watch?v=EqEqEdOx-x8 Quote Link to comment Share on other sites More sharing options...
AlexUT Posted April 12, 2021 Report Share Posted April 12, 2021 1. Delete MI 8 power-up value -Sample Time. It will be calculated by Autotune. 2. Water temperature range is 0 to 100. It is recommended to set: - MI 9 =0 (0.0) - MI 10 = 1100 (110.0) 3. MI 0 show temperature in 0.1 C/F. 4. Change User Set point MI 47 format to 4.1 Entering 55.1 from display will be represented as 551 in MI. 4. Use MI 47 instead of MI 3. 5. Sample MI 0 in 4.1 format. 6. Delete nets 2 and 3. Test it. 1 Quote Link to comment Share on other sites More sharing options...
Action22 Posted April 14, 2021 Author Report Share Posted April 14, 2021 thank you so much for taking the time to go through the program and giving us prompt feedback. Greatly appreciate it!! Quote Link to comment Share on other sites More sharing options...
Action22 Posted April 15, 2021 Author Report Share Posted April 15, 2021 Auto tune is completing. Thanks for the advice! Quote Link to comment Share on other sites More sharing options...
