Bourdon Posted April 27, 2021 Report Share Posted April 27, 2021 Hello I try to translate a two steps Grafcet with Set/Reset. But when i test my program, the Set/Reset coils arec energized at the same time. In the documentation we can read that : A reset coil turns a set coil OFF (unlatches), when the preceding net conditions are ON, allowing power flow to reach the reset coil from the net. Once a set coil is turned ON, it stays ON, independent of the original set condition, until a reset coil linked to the same address resets (unlatches) the coil condition. Thanks for your help SR test.vlp Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted April 27, 2021 MVP 2023 Report Share Posted April 27, 2021 Moved to the correct forum. Link to comment Share on other sites More sharing options...
Bourdon Posted April 27, 2021 Author Report Share Posted April 27, 2021 forgotten to say I have Samba and I use Visilogic Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted April 27, 2021 MVP 2023 Report Share Posted April 27, 2021 3 hours ago, Bourdon said: But when i test my program, the Set/Reset coils arec energized at the same time. I think you're misunderstanding the power flow designation in VisiLogic. When a coil is energized it will show as red when online in VisiLogic. The fact that the coil is a SET coil, RESET coil, or direct coil is irrelevant to showing it energized. Whether a SET or RESET in VisiLogic, it's still the same coil and will be visualized the same. What you need to be looking for is complete power flow from the left rail to the coil. Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted April 27, 2021 MVP 2023 Report Share Posted April 27, 2021 Further to Flex's answer, Visilogic also has a quirk where it simply reads the state of operands when you are online. In doing the read this way it will also show things with Red (if that's the colour you have set for Power Flow ) in a subroutine that is NOT being called. This easily leads to confusion as to why something isn't working as expected. This has caught out many people and you need to be aware of it. Members here often have a dedicated personal method at the top of each sub to definitely show when it is active. cheers, Aus Link to comment Share on other sites More sharing options...
