Patko Posted May 7, 2021 Report Share Posted May 7, 2021 Hi, can anyone please advise me. This temperature sensor can be used for PLC Unistream U-USC-B10-TR22, 10DI, 2AI, 2TO, 8RO. If not, what sensor to use so that it can be used with this plc. The project is a hygienic container where we need to measure the temperature of waste during fermentation. Link for sensor: https://www.tme.eu/sk/details/se011/teplotne-sondy-a-adaptery/pico-technology/ Quote Link to comment Share on other sites More sharing options...
DanT Posted May 7, 2021 Report Share Posted May 7, 2021 Hi; The Sensor is PT-100 and will NOT interface directly to the USC-B10-TR22. You can add the UIS-04PTN PT-100 Module, or find a way to communicate with the USB-PT-104 they supply. ( I do not see an English version of the documentation) DanT Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted May 7, 2021 MVP 2021 Report Share Posted May 7, 2021 You can also find sensor with 4-20mA or 0-10V output, or use PT100 to 4-20mA separate converter. Quote Link to comment Share on other sites More sharing options...
Patko Posted May 10, 2021 Author Report Share Posted May 10, 2021 Thanks for the answers. When I use the UIS - 04PTN module, I can also use these PT100, 2 wire sensors? https://www.distrelec.sk/sk/kabelovy-snimac-teploty-pripojeni-pomoci-vodicu-50-350-htf50-pt100-glas-thermasgard-regeltechnik-gmbh-htf50-pt100-glas-5m/p/30000917?q=pt100&pos=87&origPos=160&origPageSize=100&track=true Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted May 10, 2021 MVP 2021 Report Share Posted May 10, 2021 6 hours ago, Patko said: I can also use these PT100, 2 wire sensors? Yes. This is original connecton for 3 different types of sensor I try to use "Paint" for show only 2 wire PT100 on all inputs Quote Link to comment Share on other sites More sharing options...
