Mad Max Posted July 23, 2021 Report Share Posted July 23, 2021 Hi people. I'm new in PLC programming and it's difficult to read all forum to find exact answer. Regards to examples and videos now it's mostly ok for me. I maked some simple programs and they work well. Now I'm working on real project and time from time I have some qiuestions. Yestarday I understod how works CAN and finely begun to send-receive data. Can I make my own topic to ask all I have? What the questions I have now: 1. Visilogic- latest ver. Win 10 64 . Each second error program terminated. It's boring. 2. Error 702-HW config doesn't support I/O. Ofcourse. TA-22 have 12 in and 8 out only, Also I use some of them. So I set start I/O from RC1 to I20 and O20. If I set them to i/o 0- no problem. Everything is working, but this error disturb me. And I cant change CAN subrootine now. 3. Each "DownIoad" to PLC I have "invalid operation at current State9" But there nothing present. I tried write programm from the ground new but no result. 4. I used RC1 programm ver 7.xx without verswapper. Is it critical? Thanks for reply. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted July 23, 2021 MVP 2021 Report Share Posted July 23, 2021 Hi Max, do you really know what a Ford Interceptor is? 🙂 Some quick answers to your questions. Much of what you're asking sounds like you haven't installed properly. See here: https://forum.unitronics.com/topic/7917-visilogic-doesnt-work-properly-after-installation-what-install-as-administrator-really-means/ Also have a look through this topic and you will find other things that you are talking about: https://forum.unitronics.com/topic/6229-ongoing-18-topics-almost-worth-pinning/ Come back again after investigating all of this. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Mad Max Posted July 24, 2021 Author Report Share Posted July 24, 2021 Ha! Mad Max 1-2 my favor cinema. Actually I'm not Mad Max in life. I close to Night Rider- I like night driving. But real my name is Max. Okay, fist thank's for reply. yestarday I call Engineer of Klinkman Ukraine and he explain me all. So simple mistakes.... About programm- I remove it, reboot and install again. Only after that all problems gone. Just run as admin- doesn't work. About 702 Error- of course I should set Vector to MB's not to I/O ! Also I forget to call sub. This is why Linearisation doesn't work. So now I doing my project and only I can say- Unitronics is great solution for dummyes like me But one thing is unusefull- impossible open 2 project at ones to copy parts of programm, Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted July 24, 2021 MVP 2021 Report Share Posted July 24, 2021 9 hours ago, Mad Max said: But one thing is unusefull- impossible open 2 project at ones to copy parts of programm, Please read this post completely to get multiple instances. Pay attention to the very last post.....you cannot copy/paste. However, if you set your operand numbers up so there is no "overlap", you CAN use export/import subroutine. But at least you can get 2 multiple instances on screen to compare what you've done....and manually copy. https://forum.unitronics.com/topic/4015-multiple-connection-live-checking-tip/ cheers, Aus Quote Link to comment Share on other sites More sharing options...
