Alarm history and SD-Card:
Hi,
Just checking:
I'm trying to avoid filling up the sd-card.
Now I am controlling the SB 352 on SB2  "always" on bit.
Does this filling up the sd-card...... ?
Is there automatic remove of the oldest alarms ?
Best Regards,
Rainer Halme
Fill time is obviously determined by the size of the SD card.
PLC data is byte-size, and is not large at all.  I did a datalogging test a few years back when 4 GB cards where a thing, and I ran a once-per-second log of 30 time-stamped MIs.  After a month it had created a 250 kB csv file.
From the Help:
The PLC can support up to a 32 GB card.  If you put one of these in there I don't think you have to worry about it.
The oldest alarms are NOT removed.
