pa_dirt Posted September 15, 2021 Report Share Posted September 15, 2021 I am very new to programming and only know what I've taught myself..... I have a toggle button on the hmi to turn the a water pump on, I hade it working fine and cleaned up some of (what i thought) unused bits and now cant get it working again. It just rapidly toggles back and forth. Can someone tell me what I am doing wrong? Quote Link to comment Share on other sites More sharing options...
pa_dirt Posted September 15, 2021 Author Report Share Posted September 15, 2021 figured it out.... well i got it to work how would you guys have done it? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted September 15, 2021 MVP 2021 Report Share Posted September 15, 2021 Moved to the VisiLogic forum. Quote Link to comment Share on other sites More sharing options...
dierkens Posted September 15, 2021 Report Share Posted September 15, 2021 2 hours ago, pa_dirt said: figured it out.... well i got it to work how would you guys have done it? Post your solution so that others can see how you solved it. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted September 15, 2021 MVP 2021 Report Share Posted September 15, 2021 If it's just a toggle button to turn a pump on or off, you don't need ANY ladder logic at all. Simply assign the output to a binary text switch and check the Toggle box. Quote Link to comment Share on other sites More sharing options...
pa_dirt Posted September 15, 2021 Author Report Share Posted September 15, 2021 flex727 ---i knew there had to be an easier way just took it out of the logic and used simple binary switch Thanks again Quote Link to comment Share on other sites More sharing options...
