brugola Posted September 16, 2021 Report Share Posted September 16, 2021 my laptop have only an rj45 socket. How should I connect my PC to the PLC? Thanks. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted September 17, 2021 MVP 2021 Report Share Posted September 17, 2021 Not tested but maybe MOXA NPort Ethernet-to-RS232 can be used. If Bluetouth on board present - simple Bluetouth-RS232 convertor also useful. Quote Link to comment Share on other sites More sharing options...
DanT Posted September 17, 2021 Report Share Posted September 17, 2021 HI; Does your Computer have USB Port? Then you can use the RS232-Com Cable and a USB to DB9 RS232 Adapter. DanT Quote Link to comment Share on other sites More sharing options...
Action22 Posted September 19, 2021 Report Share Posted September 19, 2021 If you only have the RJ45 port on you PC maybe a RJ45 rollover cable would work. Quote Link to comment Share on other sites More sharing options...
