Giovanni Fatigati Posted October 29, 2021 Report Share Posted October 29, 2021 hi everybody, I have a SM35-J display that I programmed with VisiLogic. I saved the VLP file on my pc, but I am not able to find it through Windows 10 explorer. I have "show hidden files enabled", nevertheless the file is not visible. I tried also through a powershell, but also this one doesn't work. Can aneone explain me why and how I can see the files? Many thanks Giovanni Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted October 29, 2021 MVP 2021 Report Share Posted October 29, 2021 The default location for VisiLogic project files is C:\Windows\Program Files (x86)\Unitronics\Unitronics VisiLogic_C\Applications\ Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted October 29, 2021 MVP 2021 Report Share Posted October 29, 2021 Further to Flex's answer, wondering whether it might have been saved to the "cloud"? There are laptops etc these days that default to storing and using everything via the cloud. I think it's a really dumb way of doing things, but that's the way some people like it....according to the makers who want to flog the concept. 😱 and a PS. I've also had instances, (not with anything Unitronics) where the file extension is not automatically added to the file name on save. The file is there, but needs to be searched for as if it doesn't have an extn at all. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Giovanni Fatigati Posted November 2, 2021 Author Report Share Posted November 2, 2021 SOLVED When I run VisiLogic it asks for the administrator rights. Running as adminsitrator the default directories are administrator's ones. From my account I did not see the file since I was searching in the user forder which is different. Quote Link to comment Share on other sites More sharing options...
