Janis Latvia Posted November 8, 2021 Report Share Posted November 8, 2021 Vision V570 RTC to ASCII data history values start fast blinking on screen after replacing old V570 to new one V570 with USB.Same programm,VisiLogic 9.8.65.Untill this everything worked perfect,I have screen Data History,where can be saved up to 5000 values with 15.minutes interval- dd/mm/yy,seperately hh/mm/ss (RTC to ASCII) and beside analog water level value,which not blinking.Tried everything,no more ideas.PLC is at small Hydroelectrical Power Station.Help me,please,if You can.Thank You. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted November 8, 2021 MVP 2021 Report Share Posted November 8, 2021 If it is possible to connect to old PLC - you can read operand and save it. After download project to new PLC - you can write saved operand from file. I think you simply do not remember timer value setup and if it resetted to 0 - blinking is normal behavior Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted November 8, 2021 MVP 2021 Report Share Posted November 8, 2021 Kratmel is likely correct. The unanswered question is "how fast"? On the forum there have been references to extremely fast blinking being caused by screen section overlaps. I know this shouldn't be the case in a change-over scenario, but perhaps worth checking to see if it makes a difference. Look for anything on that screen that is close together and re-arrange slightly to test. cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted November 8, 2021 MVP 2021 Report Share Posted November 8, 2021 You can also check V570 firmware version in .xls file provided by Ausman I do not know what changes in latest version. Quote Link to comment Share on other sites More sharing options...
