Vision Expansion Module Supplies Needed. ( IO-DI8-R08)
Hello,
This is probably not the place to look for parts but I thought I would try.
I am coming up short on (12) expansion modules ( IO-DI8-R08) or (IO-DI8-T08) and I am having a hard time locating some within my needed time frame. My dealer is saying 4-6 weeks from Unitronics.  Anyone know of a stocking supplier to check out within the US?
Thanks.
Cordell, although not quite the way you planned, perhaps you could use the IO-D16A3-TO16 variations instead.  It might actually work out cheaper for you, as the EX variant is an adapter. These I/Os aren't known a lot, but can be found here under I/O expansion modules  /   XL Digital/Analog:
https://www.unitronicsplc.com/io-expansion-modules/
cheers, Aus
and a later edit,   In saying this, I was thinking that you might have been having a few of the 8s, so that 1 x 16 would = 2 x 8.  But if you're only wanting one 8 per job, then please ignore the suggestion!
