PeterPan217 Posted February 16, 2022 Report Share Posted February 16, 2022 I'm trying to find out how/if I can add a branch to a line of programming in VisiLogic. This is my first program I'm trying to write on there and am much more used to the RS Logix series. I believe I have most of it figured out but the program I'm trying to write would be much easier with the ability to add a branch. Does anyone know how I can do this? Or a nice work around that will do the same thing? I'd appreciate any input. Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted February 16, 2022 Report Share Posted February 16, 2022 46 minutes ago, PeterPan217 said: I'm trying to find out how/if I can add a branch to a line of programming in VisiLogic. This is my first program I'm trying to write on there and am much more used to the RS Logix series. I believe I have most of it figured out but the program I'm trying to write would be much easier with the ability to add a branch. Does anyone know how I can do this? Or a nice work around that will do the same thing? I'd appreciate any input. What do you mean by branch, like this? you can use the connect elements button to ... connect elements Quote Link to comment Share on other sites More sharing options...
DanT Posted February 16, 2022 Report Share Posted February 16, 2022 Hi Peter; Are you trying to do a Jump type branch? Jump to a Labeled Net? Under Help, Examples, Version 900, Projects , Ladder, see V280 Label Loop example program. DanT Quote Link to comment Share on other sites More sharing options...
John_R Posted February 16, 2022 Report Share Posted February 16, 2022 Just add your operands and connect them as a branch Double click the left mouse button, a crosshair shows up showing you can draw lines to connect the branch. Quote Link to comment Share on other sites More sharing options...
PeterPan217 Posted February 16, 2022 Author Report Share Posted February 16, 2022 Fernando, John....thank you very much. I had connected my operands using that tool but had no idea if that was remotely correct or not. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted February 16, 2022 MVP 2021 Report Share Posted February 16, 2022 42 minutes ago, PeterPan217 said: but had no idea if that was remotely correct or not. Unitronics has many tutorials available on YouTube (and here on this forum) and there are example projects that came with your VisiLogic installation. I recommend them. Quote Link to comment Share on other sites More sharing options...
