Compensação de temperatura no V130
Hi, i do not know V130 model present on foto.
Inside the V130-33-TA24 Unitronics PLC contains an MCP9801 chip for thermal compensation of the thermocouple cold junction.
It is located directly next to the TC connector on the PLC I / O board - on the back of the board.
Therefore, I think that all those PLCs that support thermocouples have similar compensation.
On the pages 3-4
https://www.unitronicsplc.com/wp-content/uploads/2016/08/Vxxx_J_TA24_SPEC_02_16.pdf
you can see TC input parameters and info about automatic cold junction compensation.
