Antal Posted April 11, 2022 Report Share Posted April 11, 2022 Hi UniLogic ver 1.31.146 We have our own MQTT server. We are using a different port than standard. Thanks in advance Greetings Antal Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 11, 2022 MVP 2021 Report Share Posted April 11, 2022 I would say either change the port to 8883 or just ignore the message. Warning messages can be ignored. Quote Link to comment Share on other sites More sharing options...
curtharrington1 Posted April 19, 2022 Report Share Posted April 19, 2022 On 4/11/2022 at 1:52 PM, Flex727 said: I would say either change the port to 8883 or just ignore the message. Warning messages can be ignored. There really should be a way to disable certain warnings. I've worked for employers that would not allow software to be released to production if there were any warnings from compile Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 19, 2022 MVP 2021 Report Share Posted April 19, 2022 22 minutes ago, curtharrington1 said: There really should be a way to disable certain warnings. I wish there were also. The warning message should be able to be acknowledged, then disappear. Quote Link to comment Share on other sites More sharing options...
Antal Posted April 23, 2022 Author Report Share Posted April 23, 2022 Thanks for the reply. Unfortunately, this is the case. The Software is running without error. Greetings Antal Quote Link to comment Share on other sites More sharing options...
