3asbbq Posted April 14, 2022 Report Share Posted April 14, 2022 Scenario: I have JZ10's already programmed that I would like to pull the OS and projects from to install on a new JZ20. I purchased the programming kit and am experimenting with it, but am having trouble just communicating. I get to the point when U90 Ladder is synchronizing Com Ports and then I get an error saying communications could not be established. Any help, or point me at a tutorial, would be greatly appreciated. I've read through everything I can find in the help section but am still stuck. Thanks! Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted April 14, 2022 MVP 2021 Report Share Posted April 14, 2022 This topic maybe useful Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted April 14, 2022 MVP 2021 Report Share Posted April 14, 2022 Also, if none of the referenced topic solves your issue, what Windows version are you using? Quote Link to comment Share on other sites More sharing options...
