Felipe Posted April 22, 2022 Report Share Posted April 22, 2022 We programmers need this things in Unistream, to save time: Can be able indexed access of tag type array Can be able to create struct inside struct Can be able to instance timer on UDFB for example in a struct, when use timer on fb you need create each timer separately passing as Input. (I Created My owner TON, to "solve" it) Can be able to instance memory pulse trigger in UDFB, same case of time Can be able to open two or more instances of the unilogic software. Please Unitronics solve it!!! Sorry about my english, I'm learn it yet. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 22, 2022 MVP 2021 Report Share Posted April 22, 2022 I split this comment off to a new topic in a more appropriate forum. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted May 9, 2022 Report Share Posted May 9, 2022 Hi! @FelipeI submitted your requests to the team. I think that some are not possible...but, our team is very inventive 🙂 Thanks for submitting - many features have been added to our products in response to user requests! Quote Link to comment Share on other sites More sharing options...
SJith Posted March 3 Report Share Posted March 3 Thank you for posting this. I was searching for an answer to the same issue for a while. Quote Link to comment Share on other sites More sharing options...
