2 hours ago, Ausman said:
??????     Registered to what?????
I think he means registered to this forum - or maybe his VisiLogic isn't registered. Either way, irrelevant to his question. I think the answer is no, but there may be workarounds (use indirects for all trend settings) if he doesn't need to see history data.
no,  if you want to display all of them at the same time in the same screen, but you an split them.
or you could enable a remote data logging service over a network and store everything on a computer.
I recently implemented influxdb/telegraf stack and I collect data over modbus tcp/ip. then I use another software called grafana to make dashboards  and visualize data on a nice web browser based dashboard.
I had like 15 trends splited over 2 screens in the PLC and now I no longer use the built in trends function.
