leen Posted May 9, 2022 Report Share Posted May 9, 2022 Hi, Is it possible to sync the RTC time and date with a server, i.e.. on the internet. This to keep the PLC time correct. Now I can see only the possibility to sync it with the PC time by using Unilogic. But I want do this i.e. daily by using a sync with the internet time. Can somebody give me support if it is possible or not. Regards Leen Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted May 9, 2022 MVP 2021 Report Share Posted May 9, 2022 You set up syncing to a time server in UniApps. Open the UniLogic Help and search for "Set the RTC". Display the topic is "Setting the RTC". Joe T. Quote Link to comment Share on other sites More sharing options...
leen Posted May 12, 2022 Author Report Share Posted May 12, 2022 Thanks, now it is working. The problem was that we didn't set the DNS server. That was also needed to get acces to the internet. Now the automatically syncs is working Leen Quote Link to comment Share on other sites More sharing options...
