roghenr Posted May 30 Report Share Posted May 30 Hi all experts I need help. I'm starting a project in modbus and when inserting instruction as shown, it no longer communicates online. I forgot to introduce ladder contact before. An initialize port message was shown, what does this mean? I need to program in modbus, what steps are necessary? Will this happen again since I need to program and test with a yaskawa inverter at the same time with the same port? thanks Quote Link to comment Share on other sites More sharing options...
roghenr Posted May 30 Author Report Share Posted May 30 1 minute ago, roghenr said: Olá a todos os especialistas, preciso de ajuda. Estou iniciando um projeto no modbus e ao inserir instrução conforme mostrado, ele não se comunica mais online. Eu esqueci de introduzir o contato da escada antes. Uma mensagem de porta de inicialização foi mostrada, o que isso significa? Eu preciso programar no modbus, quais passos são necessários? Isso acontecerá novamente, pois preciso programar e testar com um inversor yaskawa ao mesmo tempo com a mesma porta? obrigado Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted May 30 MVP 2021 Report Share Posted May 30 You normally place SB 2 in front of configuration function blocks. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted May 30 MVP 2021 Report Share Posted May 30 6 hours ago, roghenr said: I need to program in modbus, what steps are necessary? Will this happen again since I need to program and test with a yaskawa inverter at the same time with the same port? Please read this topic, I recommended to put an additional card for the ability to configure modbus and watching the PLC online through the Visilogic. You can also use additional Ethernet card for Visilogic connection. Quote Link to comment Share on other sites More sharing options...
