roghenr Posted June 21 Report Share Posted June 21 Good afternoon. I have plc vision 350 with usb port and com1, could I use the mini usb port to debug program and the port com 1 for modbus 485 at the same time? I live in Brazil and I have difficulty acquiring the V100-17-rs4x board Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted June 21 MVP 2021 Report Share Posted June 21 No you cannot. Note this section in the product installation guide: Quote Link to comment Share on other sites More sharing options...
roghenr Posted June 21 Author Report Share Posted June 21 8 minutes ago, Flex727 said: Não, você não pode. Observe esta seção no guia de instalação do produto: Thanks flex needed to be sure. Now I needed to buy the optional card but I'm having trouble buying it in person Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted June 21 MVP 2021 Report Share Posted June 21 These may not be the cheapest options, but they will probably be delivered to you fairly quickly. RS485 isolated RS485 not isolated However, you can also buy the Ethernet communication module for Visilogic connection and use port1 (PLC com1) for RS485 connection. Ethernet communication module Quote Link to comment Share on other sites More sharing options...
