Buddy123 Posted July 1, 2022 Report Share Posted July 1, 2022 Hi I am trying to connect a Samba PLC to a SEW MDX61B VSD via Ethernet and using Modbus TCP. Using the function blocks in the Samba program I can get it to connect to the SEW VSD but when I try and read an address which the SEW guys say is correct, 8320 which is the encoder position it shows a status fault code of 7. I can connect the same program to a Jazz PLC and read an address in it. The Samba is the Master and SEW the slave, can someone help, I think it looks like a case of just the wrong address or maybe an extra number before it Thanks Phil Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted July 1, 2022 MVP 2021 Report Share Posted July 1, 2022 Hi, maybe you have the latest firmware in in Samba. Please use Visilogic 9.8.65 and download firmware from this version for test. Write back about the test results Some tips in topic Quote Link to comment Share on other sites More sharing options...
DanT Posted July 1, 2022 Report Share Posted July 1, 2022 Hi; Have you reviewed how VisiLogic Handles Modbus register addressing? MODBUS Help is hard to Find in Help, but start here: ( there is a lot of info there- just well hidden ) Help, Index, MODBUS Find and look at Slave Addressing. Notice the SAMBA ( Vision Color) addressing is set up in HEX ( Base 16) Know how to convert Decimal to Hex and back -- Unitronics will do it automatic , but beware ! in the example illustrated 7028 is Hex 0x7028 = 28712 decimal So is 8320 Decimal or Hex? 8320 Decimal = 0x2080 ( H-2080) 0x8320 Hex = -31968 decimal ( MI's are Integers +/- 32767) Just something to consider DanT Quote Link to comment Share on other sites More sharing options...
