Harperj Posted August 2, 2022 Report Share Posted August 2, 2022 I'm trying to connect to a USC-P_B10 PLC with a USP-070-B10 HMI via a Secomea SiteManager. My company is currently using Unilogic Verson:1.32.61. I am able to connect to the Unitronics within the Secomea "tree", I am then able to ping the address successfully from the command prompt, but Unilogic is unable to find the address under the PC-PLC Communication tab. I have tried various things with no luck. Any help with this would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted August 3, 2022 MVP 2021 Report Share Posted August 3, 2022 Moved to the UniLogic forum. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted August 5, 2022 MVP 2021 Report Share Posted August 5, 2022 Does the Secomea allow all the ports needed to connect to a UniStream over Ethernet? Search the UniLogic Help for "port" to see what ports are used by UniStream and verify that the Secomea is not blocking them. Joe T. Quote Link to comment Share on other sites More sharing options...
