lesmar96 Posted August 23, 2022 Report Share Posted August 23, 2022 Good Day, From my experience, it looks like the V570 only supports static ip addressing. I was hoping to switch our to DHCP since they do not need a static ip for anything. But it doesn't look like the V570 supports DHCP. Is that correct or am I missing it? Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted August 23, 2022 MVP 2021 Report Share Posted August 23, 2022 1 hour ago, lesmar96 said: But it doesn't look like the V570 supports DHCP If you need advanced network functions for this type of PLC, you should probably pay attention to the new service from Unitronics - Unicloud. https://unitronics.cloud/unicloud_help/UCR_Routers__Creating_and_Connecting_Assets.htm And the new product from Unitronics UCR router https://unitronics.cloud/routers/ Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted August 23, 2022 Report Share Posted August 23, 2022 you can use DHCP on v570, there is an example that I've used before, and works great, however, I don't recommend DHCP on industrial Networks, usually, you set the ips for specific devices and you don't want that an automatic IP assignment could break your network. Quote Link to comment Share on other sites More sharing options...
lesmar96 Posted August 30, 2022 Author Report Share Posted August 30, 2022 you can use DHCP on v570, there is an example that I've used before, and works great, however, I don't recommend DHCP on industrial Networks, usually, you set the ips for specific devices and you don't want that an automatic IP assignment could break your network. Where I can I find this example? I'd appreciate it. Yes, I certainly understand your concern. But we are planning to provide static addresses from the DHCP server rather than on the plc itself. Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted August 31, 2022 Report Share Posted August 31, 2022 6 hours ago, lesmar96 said: Where I can I find this example? I'd appreciate it. Yes, I certainly understand your concern. But we are planning to provide static addresses from the DHCP server rather than on the plc itself. PLC tools and applications | unitronics (unitronicsplc.com) Quote Link to comment Share on other sites More sharing options...
lesmar96 Posted August 31, 2022 Author Report Share Posted August 31, 2022 Thanks so much! I will check that out. I looked in the examples in visilogic, but hadn't found this site. Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted September 3, 2022 Report Share Posted September 3, 2022 On 8/31/2022 at 10:16 AM, lesmar96 said: Thanks so much! I will check that out. I looked in the examples in visilogic, but hadn't found this site. I know.... I wouldn't say that Unitronics is the best at maintaining proper documentation. But to be fare that happens a lot with other brands too, "application notes", "expert knowledge" or however everyone chooses to name that hidden section with useful information 😂😂 Quote Link to comment Share on other sites More sharing options...
