MELDAW Posted January 5 Report Share Posted January 5 Hello everyone, i was wondring if i can use the function Load DTI from file, and use a csv file to load it to my DTI, is it possible? Thank you. Quote Link to comment Share on other sites More sharing options...
NoamM Posted February 16 Report Share Posted February 16 Hi, the 'Load DTI from file' only except a *.udtf files. However you can use And then use 'Load DTI from file'. Quote Link to comment Share on other sites More sharing options...
