Daniel_EWW Posted January 31 Report Share Posted January 31 A user is logged out automatically after a download without reset. What is the reason of the auto log out after a download? Is there a system bit which tells me that a download was executed? Background: On the HMI we have a field that shows if a user is currently logged in. I don't know how to hide this field without a User Access Control Struct update event. Thanks, Daniel Quote Link to comment Share on other sites More sharing options...
walle Posted February 3 Report Share Posted February 3 Also have this same question using UAC. It is a nuisance to have to log back into the HMI every single time for a minor download when building / testing a program. marking UAC system struct as retained throws an error list warning that it is not recommended (still forces login anyways) Anybody know a work around / way to Enable/Disable UAC without Restoring all Defaults? Even a way to store the User name to the login box without needing to select from the drop down menu would save a couple steps and help. Thanks! Quote Link to comment Share on other sites More sharing options...
NoamM Posted February 16 Report Share Posted February 16 Hi walle & Daniel_EWW, We opened a bug regarding this issue. Will be fixed on the next software release. 1 Quote Link to comment Share on other sites More sharing options...
Daniel_EWW Posted February 20 Author Report Share Posted February 20 Perfect, thanks! Quote Link to comment Share on other sites More sharing options...
