ZK0 Posted February 16 Report Share Posted February 16 I've recently been experiencing trouble saving program files, I'm given the following error message Save Failed (174) Disk is full, or write protected, replace the disk and try again. Error number (507) The files I am working on are saved to my desktop. After I clear the error message it brings up a Save As window, at which point I "replace" the old file with the new file of the same name. Before this week, I've been able to save normally with no trouble. Been running 9.8.95 for a while now. I haven't been able to find any documentation on this error or mention of it in the forums, hoping one of yall might be able to offer some guidance. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted February 16 MVP 2021 Report Share Posted February 16 I haven't run across this particular error, and this is probably not a solution (but who knows?), however, I strongly recommend upgrading to 9.8.96. Files saved with 9.8.95 open seamlessly with 9.8.96 and 9.8.96 files do not require any firmware upgrade on the PLC that is running with 9.8.95. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted February 19 Report Share Posted February 19 Each of Windows updates add more security and require to correct access rigts, especially to allow write/store to directories you previously stored without problems. It is recommended to consult IT (or find at Internet) how to allow to store project files to specific directory. So there is not a Unitronics software problem.B.R. Quote Link to comment Share on other sites More sharing options...
ZK0 Posted February 20 Author Report Share Posted February 20 Thanks for the responses, Flex and Alex The problem seems to have resolved itself as of this morning, without any interference on my part. Perhaps IT did some updates over the weekend. Quote Link to comment Share on other sites More sharing options...
DanT Posted February 21 Report Share Posted February 21 Hi; I recently ran into a similar issue In VisiLogic involving project restores giving me similar disk full messages. I did the following : Project Restore delete some of the older projects DanT Quote Link to comment Share on other sites More sharing options...
