Sebik76 Posted February 21 Report Share Posted February 21 Hello and welcome. Is it possible to convert the V430 driver program to another type v 350. I have a project from the V430 driver, unfortunately it is damaged, now I only have the V350. I would like to transfer the program to another. Is there any way. Regards Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted February 21 MVP 2021 Report Share Posted February 21 You can open the V430 program and select a V350 from the hardware definition. It will delete any graphics that overlap the difference between the screen resolutions, but the logic will stay. You'll have to go through and re-do your screens. Joe T. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted February 23 Report Share Posted February 23 Or you can modify displays in copy of V430 project to fit V350 display, than you will be able to convert project to V350. Anyway, check if all displays are complete after such changes. Quote Link to comment Share on other sites More sharing options...
