mep23 Posted April 11 Report Share Posted April 11 Hello im a basic touch screen man and have purchased remote i/o's for a job. i will be using 1 x UN-EX-RC1 with 2 x UN-IO-DI6A3-TO16 in one section then 1 x UN-EX-RC1 with 2 x UN-IO-DI6A3-TO16 in another section. I haven't a clue how to make the V1210 communicate with CANbus . can someone help with that program side? Regards Mark Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 11 MVP 2021 Report Share Posted April 11 Example programs came with your VisiLogic installation. Look under Help/Examples... Drill down and you'll find what you need. Quote Link to comment Share on other sites More sharing options...
mep23 Posted April 11 Author Report Share Posted April 11 Hello Flex727 I have looked in the examples and found the EX-RC1, Do i use that ladder program ? sorry for sound thick but this is a bit above me. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 11 MVP 2021 Report Share Posted April 11 Yes, you can use that modified for your needs. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted April 11 MVP 2021 Report Share Posted April 11 Also have a good read of point 4 in the "almost worth pinning" topic. cheers, Aus Quote Link to comment Share on other sites More sharing options...
