Yukiko Posted May 31 Report Share Posted May 31 Each time I try to connect with the Serial it pops the Communication Drive Error 206. I'm sure that the Port is correct and already try with all baudrates and also to increase the timeout and nothing. Is there anyway to reboot from factory without the serial or to force the comm. Regards Quote Link to comment Share on other sites More sharing options...
MVP 2022 kratmel Posted May 31 MVP 2022 Report Share Posted May 31 Please post PLC model # Quote Link to comment Share on other sites More sharing options...
Yukiko Posted May 31 Author Report Share Posted May 31 Samba 3.5" SM43-J-TA22 Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted May 31 Report Share Posted May 31 I´ve had this problem in the past. The solution to me was to change the port number (12 in the image) in device manager (Windows side) to a lower port. Currently I use port 4. Quote Link to comment Share on other sites More sharing options...
MVP 2022 kratmel Posted May 31 MVP 2022 Report Share Posted May 31 Please read topic with pin Quote Link to comment Share on other sites More sharing options...
Yukiko Posted May 31 Author Report Share Posted May 31 I could solve it going inside the boot (tapping the screen in the startup) and for there download another program, because each time the PLC started somehow was killing the serial comm. Regards Quote Link to comment Share on other sites More sharing options...
