Anloge value not getting some channel
Sir ,I am facing problem in Analogue input
Some channel getting value and some Channel not get any value
I am using 4-20mA 10 bit
A0 getting value but A1 not getting any value
A2 getting value but A3 not getting any value
Please inform me reason
  • MVP 2022
Moved to the correct forum.
For a 4-20 mA signal, do you have the jumpers set properly inside the module?
If so, remove the input signal and measure the resistance between the input terminal and the COM terminal.  It should be 500 ohms.  I've been known to connect 24VDC directly to a 4/20 analog input and frying the resistor.
Thanks for reply
I have tasted with current injector.jumper setting also correct.
A0  A1 Com.         A2 A3 Com   A4 A5 Com.
My sensor connected all channel and getting value A0,A2,A4.
I am using  CPU V200 with Ex module
