djeanry Posted July 11, 2012 Report Share Posted July 11, 2012 We are trying to communicate with a V570 throught ethernet with a Siemens S7, but we don't get it running. Does anybode have some experience with this? We followed the whole manual from the S7 and nothing special. I could already communicate with another v570 in the network. I would like to keep one v570 as a master and the Siemens S7 as a slave. Some help would be very appreciated. Regards Henri Quote Link to comment Share on other sites More sharing options...
AlexUT Posted July 12, 2012 Report Share Posted July 12, 2012 Hi Henri, What protocol via Ethernet would you like to use? MODBUS TCP? You should configure S7 Ethernet, IP address, open Socket at S7 in Slave mode (Listen), and configure S7 for MODBUS, and then connect from V570 to S7 IP and Socket. BR. Quote Link to comment Share on other sites More sharing options...
djeanry Posted July 26, 2012 Author Report Share Posted July 26, 2012 Yes indeed, I would like to use modbus TCP. I tried to do so, but I don't get any data over. Do you have some example programs for this? Regards Henri Quote Link to comment Share on other sites More sharing options...
External Moderators Nacho Posted July 26, 2012 External Moderators Report Share Posted July 26, 2012 There are examples of MODBUS TCP in the help of Visilogic, I think for V280 but it is easy to convert to V570 Quote Link to comment Share on other sites More sharing options...
Fabios Posted July 29, 2012 Report Share Posted July 29, 2012 To use Modbus TCP with unitronics is very easy. With siemens the problem i a little more big. You must to buy cp341-1 and his driver (modbus). Total cost 1500 euro. I have performed this application some years ago and it si not very easy! I advise you to buy a Operator Panel ( i use sitek) that work as bridge. You spend 400 euro and it is very very very easy! Best regards Fabio Quote Link to comment Share on other sites More sharing options...
dahnuguy Posted August 6, 2012 Report Share Posted August 6, 2012 Fabio, Can you give an example of the the "operator panel" you mention? I agree, Modbus in Step7 is not simple or easy and when I did it a couple years ago, the function blocks that come with the module from Siemens did not work. There were also several issues getting the software to work after the correct function blocks were found. If I could avoid that with your suggestion, I would like it much better. Quote Link to comment Share on other sites More sharing options...
Damian Posted August 6, 2012 Report Share Posted August 6, 2012 @ Dahnuguy The Red Lion Data Stations as well as their HMIs can serve as protocol converters. I have used a small HMI of theirs on occassion just to bridge communication. @ Djeanry Are you using FB100? What CPU are you using an what is the physical connection you have? What version of Step 7 are you working with? Are you using a CP343-1? Quote Link to comment Share on other sites More sharing options...
sgull Posted August 7, 2012 Report Share Posted August 7, 2012 Hi Folks Just completed a project where I had to send signals to a Siemens PLC. I found the MOXA Mgate 4101 converter very simple to set up. This allows the unitronics to use modbus and the unit converts to profi-bus. Regards Denis Quote Link to comment Share on other sites More sharing options...
Emil Posted August 7, 2012 Report Share Posted August 7, 2012 Thank you denis, What is the price of this converter? Quote Link to comment Share on other sites More sharing options...
sgull Posted August 7, 2012 Report Share Posted August 7, 2012 Emil I paid €490 for the unit. I had to order on special delivery so I think this should be the maximum anyone should pay. Quite new to PLC programming but still found it easy to set up. Had some problems getting 485 to work, but worked fine on 232. (was certainly a problem on my side regarding wiring or terminating) http://www.moxa.com/product/MGate_4101_MB_PBS_Series.htm Regards Denis Quote Link to comment Share on other sites More sharing options...
Emil Posted August 7, 2012 Report Share Posted August 7, 2012 Thank you Denis! Quote Link to comment Share on other sites More sharing options...
