hotwires Posted February 12, 2017 Report Share Posted February 12, 2017 Dear Community, I couldn't find anything in the UniLogic help files about array functions. Is it just me or is the help section grossly incomplete in UniLogic ?! Visilogic seems to be very comprehensive in help topics with examples for every FB in the software. Feel some uncertainty without help topics on select functions, especially with the differences in terminology from Visilogic. Example being: a vector copy of 30 MI's in Visilogic is equivocal to "copy array part to array"?? Failed to find help topic with example. I tried to build a UDFB last night to function like Visilogic's vector linearization function and gave up. Just stacked individual linearization functions instead. I get the feeling the authors of UniLogic were not the same people who composed Visilogic. Old dog learning new tricks, I'll get there. Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 14, 2017 Report Share Posted February 14, 2017 Yes, vector copy and copy array part to array does do the same thing: Copy from one array to another (In visilogic everything was arrays), with the limitation in UniLogic, that both arrays should have the same data type. For building linearization UDFB, I would pass the Array as Function-In, along with the X1, X2, Y1, Y2,and Length tags, and the ourput array. I would then iterate on the first array, linearize the value and put it on the second array. Iteration can be done with Jump to start of region, and using Load from array from the first array, and Store to array on the second array. For example: Local tag: Index, LinValue Region1 LinValue = Load from Array1 at Index LinValue = LinValue * (Y2 - Y1) / (X2 - X1) Store LinValue to Array 2 at Index. Index++ (INC Index) If Index < Length then Jump Region "Region1" 1 Quote Link to comment Share on other sites More sharing options...
hotwires Posted February 15, 2017 Author Report Share Posted February 15, 2017 Thanks Saragani. I used the copy array part to array in my unilogic program and live tested; it works just like vector copy, just different terminology. The array linearization UDFB is more involved than I though. I was trying to link input INT, constants, and result INT as arrays of INT16's (built around the single linearization FB). Looks like it doesn't work that way. I won't lie: I'm not impressed with the "just build a UDFB" responce to features that were drag and drop, load em up and you're done in Visilogic. Unilogic is a whole new ballgame. I'll study program examples and youtube videos on UDFB's and slowly wrap my head around it. I got spoiled on the drag em, drop em, and load em up method. I don't even know what "iteration" is. So is your example C+ code? Or textual guidance for ladder/FB construction? Again thank you for the help. I want to learn how to use unilogic to it's fullest potential. I have a lot of future opportunities to use Unitronics products. The product line and pricing are outstanding. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted February 15, 2017 Report Share Posted February 15, 2017 Regarding the Help file--you are correct regarding the array functions. I hope to have this corrected by the next release. 1 Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 16, 2017 Report Share Posted February 16, 2017 Iterate means, doing a for loop, or a "Do While" loop. I've attached an example. Linearize Array.ulpr Quote Link to comment Share on other sites More sharing options...
hotwires Posted February 17, 2017 Author Report Share Posted February 17, 2017 sounds like a "FOR...NEXT " loop. I'll check out the example. PBASIC is the only programming language I ever learned. Can make a Basic stamp do some awesome stuff, lol. Not sure that I could learn C+ at my age. Maybe my kids can master it and help me out. Quote Link to comment Share on other sites More sharing options...
zed Posted August 2, 2023 Report Share Posted August 2, 2023 On 2/15/2017 at 1:14 AM, Cara Bereck Levy said: Regarding the Help file--you are correct regarding the array functions. I hope to have this corrected by the next release. Its now 2023...just sayin' Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 10, 2023 Report Share Posted August 10, 2023 @Cara Bereck Levy Can you check? Quote Link to comment Share on other sites More sharing options...
