MVP 2023 Flex727 Posted June 26, 2018 MVP 2023 Report Share Posted June 26, 2018 Perhaps someone can recommend a product to me. I need to be able to send a wifi signal from a Vision PLC (with Ethernet) to a laptop to run Remote Operator. The wifi access point or router needs to be able to run on 24v, same as the PLC. Anyone used such a beast before? Quote Link to comment Share on other sites More sharing options...
Cam Posted June 26, 2018 Report Share Posted June 26, 2018 https://mikrotik.com/product/RBmAP2nD is one we have a couple customers using. You will want to download winbox to configure it rather than using a terminal. 1 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted June 27, 2018 Author MVP 2023 Report Share Posted June 27, 2018 Thanks, @Cam! Those guys have a bunch of stuff that looks useful. I found a slightly different product made by Mikrotik that should suit my needs - the mAP. I've ordered one and I'm looking forward to its arrival next week. Quote Link to comment Share on other sites More sharing options...
kritesh Posted July 11, 2018 Report Share Posted July 11, 2018 Choose the network connection you wish to . Right click on it, select "Properties," and go to the "Sharing" tab. Check the option "Allow other network users to connect through this computer's Internet connection." This time, select the WIFI hotspot you created earlier. Direct Connection: PC-Controller Accessing a Networked Controller Accessing a Controller via Modem With the help of above you can easily work on your system. Quote Link to comment Share on other sites More sharing options...
vasovas Posted October 17, 2020 Report Share Posted October 17, 2020 Hi, did you manage to connect to SM43? i I just have received my mAP and try to solve the same task. Did you setup a brifge or switch to connect to PLC? D.Vasilev Quote Link to comment Share on other sites More sharing options...
AlexUT Posted October 17, 2020 Report Share Posted October 17, 2020 Hi vasovas, Dis you deleted your post? Or just by mistake used Strikethrough? B.R. Quote Link to comment Share on other sites More sharing options...
vasovas Posted October 18, 2020 Report Share Posted October 18, 2020 Hi, AlexUT, I used by mistake Strikethrough, my post (question) is valid. BR. Quote Link to comment Share on other sites More sharing options...
Cam Posted October 19, 2020 Report Share Posted October 19, 2020 Lot of it depends on what you are trying to do with the mAP. Quote Link to comment Share on other sites More sharing options...
vasovas Posted October 19, 2020 Report Share Posted October 19, 2020 This is SCADA project. Data are read from SM35 samba using Modbus TCP driver. All works fine, except that the cables are constant issue - often there are connectivity issues due to the dusty environment. I would like to read the data through WIFI. So the topology is SCADA server - company WIFI - mAP - SM35. Quote Link to comment Share on other sites More sharing options...
Cam Posted October 19, 2020 Report Share Posted October 19, 2020 You'll have to move the Wi-Fi from the switch to the WAN and take the Ethernet port currently being utilized as the WAN and put it in the LAN. Look under quick set there should be an option to do everything you need under that tab. We don't typically set them up that way so I'm not sure of all the settings. Send me PM if you need more info as it's not really Unitroincs item. Alternatively you could use the new UCR to do the same job. Quote Link to comment Share on other sites More sharing options...
vasovas Posted October 19, 2020 Report Share Posted October 19, 2020 CAM, thank you very much for your prompt reply! I tried with the quick set (though it is not recommended indeed), well, I did not manage to make it work, but let me play a bit to see what outcome will get. And yes, you are right, it is not really Unitronics item , I would rather use PM if necessary, once again thank you. Quote Link to comment Share on other sites More sharing options...
