Swervomotor Posted March 22, 2019 Report Share Posted March 22, 2019 Is there a way to re-order regions? in the ladder? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted March 24, 2019 MVP 2023 Report Share Posted March 24, 2019 It would make sense that you could minimize them and drag them around in the function. But I tried doing that in a function I'm working on that has four regions and it did not work. So I'm going to say "No" but I'm still working on my UniStream Genius certificate. I'd send the question to support. Joe T. Quote Link to comment Share on other sites More sharing options...
Saragani Posted March 24, 2019 Report Share Posted March 24, 2019 There isn't any way by dragging, but you can select all rungs in a region, cut it (The containing region will be deleted, since all rungs inside where cut), insert a region in the location that you want, and paste the rungs in it. You will need to give it the old name, and re-write the comment. Quote Link to comment Share on other sites More sharing options...
Swervomotor Posted March 28, 2019 Author Report Share Posted March 28, 2019 Thanks for the responses, the ole Copy-Paste-Delete all rungs was the only way I could get it done. I was hoping the labels were stored in a table somewhere that I could just re-order or drag-n-drop in ladder editor would be awesome. I will be more diligent with my planning next time. This project has ~ 50 regions so far. Quote Link to comment Share on other sites More sharing options...
