GUNNAR RONGVE 0 Report post Posted August 4 I have a problem with connecting via TCP in remote acccess. Using favorites When trying to connect this message appers. Windows 10 - 64 bit Any tips Running as Admin, UAC is off, running in XP mode..... Quote Share this post Link to post Share on other sites
GUNNAR RONGVE 0 Report post Posted August 4 I have similar problem when using Visilogic on the same laptop. Using favorites make this message, see below. But if i use project settings connection is ok. Could it be user access problems with favorite file ??? Any fix for this ? Quote Share this post Link to post Share on other sites
Flex727 213 Report post Posted August 4 It would help a lot if you showed us what was underneath those warning messages. Quote Share this post Link to post Share on other sites
Joe Tauser 285 Report post Posted August 5 Better yet, click on the Favorites button and show us that. Joe T. Quote Share this post Link to post Share on other sites
AlexUT 39 Report post Posted August 5 Open favorites (if possible) and make snapshot to save for feature reference. Close Unitronics applications/programs. Go to "C:\Program Files (x86)\Common Files\Unitronics" and rename "Eth_Favorites.evb" file to "Eth_Favorites.evb.old". Create favorites again. It should work. *Favorites file somehow damaged. 1 Quote Share this post Link to post Share on other sites
GUNNAR RONGVE 0 Report post Posted August 5 Thank you Alex. I renamed file as described, and that solved the problem. Have to put in new values in file, used screen shot to rebuild. Works well now. BR Gunnar Quote Share this post Link to post Share on other sites
