active Posted May 25, 2011 Report Share Posted May 25, 2011 Hi all Is there any way to turn off the information mode, be really handy to set/reset SB to do this because if you use remote operator and click the mouse too long V570 goes into info mode which is not supported remotely anyway. Thanks Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted May 25, 2011 Report Share Posted May 25, 2011 Hi, In order to disable the Info Mode set Si50 to 0. Quote Link to comment Share on other sites More sharing options...
active Posted May 26, 2011 Author Report Share Posted May 26, 2011 Thanks Stein Yair Quote Link to comment Share on other sites More sharing options...
External Moderators Nacho Posted June 28, 2011 External Moderators Report Share Posted June 28, 2011 Is there any way to do it with a M91 or Jazz? Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted June 29, 2011 MVP 2014 Report Share Posted June 29, 2011 From one of Ofir's posts in the old forum: if you want to disable the Info key in jazz you can set SI 178 to zero.(default is 3) When using M91/Jazz controllers you can set Info password on the System menu only and this password related to SI179. Note that when you enter new password to SI179 you will not able to see it via the U90ladder and the value of SI179 will allways shows 0. These operands are not tagged in U90 Ladder with any description. Quote Link to comment Share on other sites More sharing options...
pierre Posted July 17, 2017 Report Share Posted July 17, 2017 Il serait bien pratique de pouvoir basculer ce SB31 à 0 pour supprimer le mode "info mode" surtout quand il est bloqué en "info mode" à distance. Ce serait bien de pouvoir l'intégrer cette possibilité dans une future version soft . Quote Link to comment Share on other sites More sharing options...
