NewMember_R Posted August 12, 2019 Report Share Posted August 12, 2019 I have a PLC V350 in front of me that i want to connect via ethernet.But i dont know the IP-Adress. Is there a way to get it without the original Programm. ***And I can not upload the current Programm from PLC to my PC Quote Link to comment Share on other sites More sharing options...
Cam Posted August 12, 2019 Report Share Posted August 12, 2019 You can access the IP from info mode on the touch screen. -enter info mode -select Etherent -Select Ip parameters this will display the IP subnet mask and gateway information. You can then just keep pressing esc to exit. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 12, 2019 MVP 2023 Report Share Posted August 12, 2019 You will also need to know the PLC name to connect with VisiLogic. That's also available from INFO Mode. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted August 12, 2019 MVP 2023 Report Share Posted August 12, 2019 1 hour ago, NewMember_R said: **And I can not upload the current Programm from PLC to my PC There is a very high probability that you won't be able to upload the program. That's a permission set by the original programmer. What is your actual situation? I'm guessing from your original post that you're trying to connect to a machine and you don't know anything about Unitronics. What are you trying to do? Joe T. Quote Link to comment Share on other sites More sharing options...
