bjarni Posted August 16, 2019 Report Share Posted August 16, 2019 Hello again - as said earlier I'm starting up a project with Unistream hooked to an Ex-Rc1 and D16-A3 Thanks to you guys, I've managed to go through the config procedure as described in the training procedure: Configure Ex-Rc1 and the IO unit in Visilogic and export the config to Unilogic Read it by Unilogic and export the in/out files to Visilogic and download it to the Ex-Rc1 Verify that can ID on Unistream is 1 and 2 on the Ex-rc1 (dip on 2 also) . Baudrate 1Mb on both Test the D16-A3 IO from Visilogic - could both see input signals and set output from Visilogic In Unilogic I can see the image of the IO modules and their IO, but if I try to watch an input or set an output - nothing happens on the IO hardware??? Do I need to do something more than the configs, like some CAN send/receive in ladder? Can I see somewhere if the CAN is operating as supposed? Thanks, Bjarni Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted August 17, 2019 MVP 2023 Report Share Posted August 17, 2019 Go online and look at the IO tab -> RIO-RC Statistics Struct- Are the numbers changing? Joe T. Quote Link to comment Share on other sites More sharing options...
bjarni Posted August 17, 2019 Author Report Share Posted August 17, 2019 No - all counters on zero! Quote Link to comment Share on other sites More sharing options...
sgull Posted August 18, 2019 Report Share Posted August 18, 2019 Check the wiring on the CANBUS side. I think the connections on the unistream are not the same as EX-RC1. The blue and green wires might need to be reversed. Quote Link to comment Share on other sites More sharing options...
bjarni Posted August 18, 2019 Author Report Share Posted August 18, 2019 Thanks sgull, but they are the same on both ends - RGYBB. Not so clear on photo though Quote Link to comment Share on other sites More sharing options...
sgull Posted August 18, 2019 Report Share Posted August 18, 2019 (edited) Hi Bjarni Thats what I mean. You have wired the same at both ends, but I think the L and H of the connectors are not the same on the units. Regards Denis Sorry - I was looking at the wrong wiring diagram. Please ignore the advice above. Edited August 18, 2019 by sgull Incorrect information Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted August 18, 2019 MVP 2023 Report Share Posted August 18, 2019 The IO Comm light on the -RC1 is on, so it thinks everything is good. But the PLC program is sitting idle. Your configuration looks correct Please post both your UniStream program and your RC1 program so we're not guessing at what's inside the programs. You can also open a ticket with support@unitronics.com Joe T. Quote Link to comment Share on other sites More sharing options...
bjarni Posted August 19, 2019 Author Report Share Posted August 19, 2019 Hi, here are the programs. Thanks, Bjarni bara io.vlp UniTest.ulpr Quote Link to comment Share on other sites More sharing options...
