MaintenenceENG Posted February 24, 2020 Report Share Posted February 24, 2020 unable to figure out where to start with controlling a wire stripper to the PLC. there is no ethernet port on the wire stripper, but there is a USB port, so we are unsure how to address it in the programming and how to control it. we are hoping to be able to tell the wire stripper what gauge of wire it is stripping and many other portions. Please let me know what you have found or recommend for starting and implementing for this project. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted February 25, 2020 MVP 2023 Report Share Posted February 25, 2020 A UniStream can talk to a USB port if the receiving device is emulating a serial COM port with it. Other that that we would really need to know much more about the communication capabilities of the wire stripper. Can you post links to some information about it? Joe T. Quote Link to comment Share on other sites More sharing options...
MaintenenceENG Posted February 25, 2020 Author Report Share Posted February 25, 2020 it is The rotary Strip 2400 that we are using. I've attached the pdf we have of the wire stripper we plan to use, but we have no other information, and no idea where to start. RotaryStrip_2400_DS_EN_A4.pdf Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted February 25, 2020 MVP 2023 Report Share Posted February 25, 2020 That pdf really doesn't say much. What you need to do is contact Schleuniger direct and ask them the question of what is available and how the unit handles those possibilities. Further to my interpretation of that brochure about what the stripper does, what is it that you are actually wanting to do involving the plc? To me it looks like if you introduced a wire to the stripper correctly in a mechanical sense, the stripper would then do it's job without any further intervention. A simple time delay on the mechanical presentation by the plc would be all that is required. Present it, wait a moment, take it away. But maybe that's not what you are wanting to do. cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted February 26, 2020 MVP 2023 Report Share Posted February 26, 2020 12 hours ago, MaintenenceENG said: but we have no other information, and no idea where to start Start by registering on this web page - https://www.schleuniger.com/na/en-us/products/strip/wire-stripping/rotarystrip-2400 And downloading and post this manual- Also +1 to what Ausman says - call the manufacturer directly and tell them what you are trying to do. What part of the world do you live in? Joe T. Quote Link to comment Share on other sites More sharing options...
Swervomotor Posted March 30, 2020 Report Share Posted March 30, 2020 Schleuniger is notoriously difficult to work with on "custom" stuff. We program all ours with Iquana, but I don't think you can access /edit the "program" registers remotely. PS. have you had any issues with your HMI's on those machines? We've had several fail. Quote Link to comment Share on other sites More sharing options...
jameslandry Posted March 29, 2022 Report Share Posted March 29, 2022 I remember Knoweasy device as the best automatic wire stripping tool that I’ve previously used. I can say this because I found it easy and intuitive to use, and it also comes in an exciting color scheme. Quote Link to comment Share on other sites More sharing options...
