IgorG62il Posted May 16 Report Share Posted May 16 Hello. I have V230 plc and use Visilogic soft.In a existing project I made a small modification and when I want to download to PLC have option:simple "download" or "stop-download-run" or "stop-download-reset".Which of this option I need ,If later possible upload project? Thanks. Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted May 16 MVP 2023 Report Share Posted May 16 I rarely work with the V230, but my recollection is that upload project is enabled by default on these PLCs. You can choose any of the 3 download selections, as appropriate. Link to comment Share on other sites More sharing options...
DanT Posted May 16 Report Share Posted May 16 Hi Igor; ( expansion of Flex's Post) V230 is an older Unitroncis PLC product. Simple Answer : Stop - Download - Run - best option, take machine off line first, then do the stop-download-run then put machine online to test and run. Stop-Download-reset - Stops the PLC program, Takes the download, and restarts the PLC as if is is being powered up. Download -- downloads in the background and if necessary will stop and then run. Depending on the modifications, VisiLogic may decide to do the reset. Upload -- V230 being an older product, Program Upload is only restricted by a Program Password. No Password - Program is uploadable Password protected - upload will ask for the password. Do not know the password ? - not uploadable Some consideratons : How old is the PLC? What is the condition of the internal Battery? ( info Mode SB8 ( System Bit 8 ) Battery 1= LOW - needs changing. Since Battery is inside the PLC, Best to Back Up Memory before doing - - Changing Battery with Power OFF will clear memory and changed from default settings - like timers and MI's (counters) - VisiLogic - Connection - Export Operands to Text File ( or Binary File), Import back after battery is changed. VisiLogic - What version are you using ? an older version from when the PLC was installed ? You will probably be OK. A Newer Version used to edit the program will force you to upgrade the OS in the PLC to be compatible with the newer version of VisiLogic. DanT 1 Link to comment Share on other sites More sharing options...
IgorG62il Posted May 19 Author Report Share Posted May 19 Thanks for answer. So if I need simple download any change to PLC I use "download"option?This is enough? I use version of VisiLogic 9.8.65. Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted May 20 MVP 2023 Report Share Posted May 20 Yes. It may ask you to update the OS. The software will walk you through it if needed. Joe T. Link to comment Share on other sites More sharing options...
