Matthew Neske Posted September 4 Report Share Posted September 4 Hello, I had to replace our V290-19-b20b and the one we received powers up, but unfortunately the monochrome screen is either turned off or the SI7 is set at 0. Does anyone have any step by step procedures with pictures of how to input the factory default password and moving through the system menu to change these settings? If pictures are not available perhaps locations where to touch on the screen to select the correct option. Thanks in advance, Matthew Neske Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 4 MVP 2023 Report Share Posted September 4 Use VisiLogic to connect to the PLC, go online, and inspect and/or change SI 7. Link to comment Share on other sites More sharing options...
Matthew Neske Posted September 4 Author Report Share Posted September 4 How do I connect to the V290 with a laptop? I only have usb, usb-c , ethernet and hdmi ports. Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 4 MVP 2023 Report Share Posted September 4 You obtain a USB-to-Serial converter with a Prolific chip, such as this one: https://www.amazon.com/TRENDnet-Converter-Installation-Universal-TU-S9/dp/B0007T27H8/ and obtain the serial programming cable that came with the PLC, then connect them all together. Link to comment Share on other sites More sharing options...
Matthew Neske Posted September 4 Author Report Share Posted September 4 Thanks, So I have found the cable adapter I need and I apologize I have never used this software before, but it looks as though I was able to test the connection and I saw the plc model information. Now I am watching a video from the companies website and it wants me to downlad OS updates, but I keep getting an error after the download has completed stating the 26 files are not found. Is there a way to factory reset this device since it was a used system that I believe has another companies program on it? Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted September 4 MVP 2023 Report Share Posted September 4 Please try to go to info mode. If some issue is with contrast or britness as i know in info mode used default contrast. But maybe your plc have problem with backlight. Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted September 4 MVP 2023 Report Share Posted September 4 Hopefully the PLC still boots after the OS update failure. The post above that kratmel is referencing describes how to get to Info mode. You should be able to still read the screen by holding a flashlight up to it. If the screen is bad, the V290 is obsolete. You'll have to go to eBay or the surplus market to get a replacement. Joe T. Link to comment Share on other sites More sharing options...
