Maximum subroutine size
Is there some other limit beyond just number of nets? Visilogic is giving me a compile error on one subroutine with 118 nets (including the RET). The error message says "Subroutine ladder data size exceeds limit. Split subroutine to solve problem". It says it is "Type/Num" 55.
It's no problem to split the subroutine, just want to know what I'm dealing with here.
I have gotten this same message on programs that are well under the known ladder size limit. I believe the reason is that in the programs this has happened to me in have a large number of nets that have multiple rows of actions within that single net. I have never taken to adding it all up but I believe that if I were to add all of the program rows (not the number of nets) it may exceed the 256 limit.
Just a guess, but empirical evidence says that there is definately another limit other than just the quantity of nets.
Keith
In fact YES - there is another limit - the volume of the compiled code per subroutine. I don't remember what is the value, but it doesn't matter in fact, as it's very difficult (practically impossible) to measure this value.
Again my advices
- write simple rungs;
- put one rung per net;
- split the code to short, logical, easy to edit and debug subroutines.
In my opinion, it's not difficult to follow these advices and the programmer can only win.
This makes sense.
In my case, almost none of the nets have more than one row, but most of them have 3 Data Table function blocks each. This subroutine creates a viewable log file using data tables. Because of the complexity of the equipment this program is controlling, this subroutine was larger than I normally need. There may be a more efficient way of doing what I'm trying to do using available Vision functionality, but I haven't figured it out yet.
