russedwards Posted January 8, 2013 Report Share Posted January 8, 2013 Hi I have successfully set up my V570 to give a 4-20 mamp output that relates to my pressure transmitter input of a range of 0-4.35 psi (4 mamp = 0 psi, 20mamp = 4.35 psi) In another part of my process, I need to change this linear output so that 0.5 psi = 20mamp. Can anyone tell me how to successfully do this? When I have tried to re-linearise the output, I am still getting the original output values even though I have linked the new, linearised MI to the output. Thanks Quote Link to comment Share on other sites More sharing options...
AlexUT Posted January 8, 2013 Report Share Posted January 8, 2013 Hi Russ, Send your project to support@unitronics.com. It will be better to see it and advice you solution. BR. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted January 9, 2013 MVP 2014 Report Share Posted January 9, 2013 Certainly the suggestion to send to support is a good one. It sounds like something simple, like the wrong MI, or you have used an MI for the X1,Y1,X2,Y2 values when you intended to use a constant value. Also, for decimal values, make sure you take into account the scaling factor. For example if you have scaled in hundredths, the 0.5psi value would be entered as 50. You could also try setting up a very simple project starting from scratch, just with the linear block in it, so you eliminate other distractions and possible factors. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted January 9, 2013 MVP 2021 Report Share Posted January 9, 2013 When you have a program already written that's having problems you really need to upload it to the forum with your questions. Joe T. 1 Quote Link to comment Share on other sites More sharing options...
