jimbo Posted May 12, 2013 Report Share Posted May 12, 2013 wrote a program in VisiLogic using windows 8 and saved it. Shut down properly and when I tried to reopen VisiLogic I get the following message: "9Permission denied". I have set the User Account Controls is at a minimum. Link to comment Share on other sites More sharing options...
R.Mozes Posted May 12, 2013 Report Share Posted May 12, 2013 Hello, Please open the software's as "administrator" (Right mouse click). If software opened properly, Close VisiLogic from Project>Exit, then Go to the properties of VisiLogic shortcut and under compatibility ticked verify the Privilege Level “Run this program as an administrator”. i hope it help... 1 Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted May 13, 2013 MVP 2014 Report Share Posted May 13, 2013 I have also seen this, "Run as Admin" fixed the problem. Link to comment Share on other sites More sharing options...
jimbo Posted May 22, 2013 Author Report Share Posted May 22, 2013 Gentlemen, Worked great, thanks much. I do have another issue relative to a problem with a clock function. Can you tell me how to run the RTC in a 24 hr format? Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted May 23, 2013 Report Share Posted May 23, 2013 SI 31 holds the current time of the RTC in 24-hour format. Is that what you need? Link to comment Share on other sites More sharing options...
jimbo Posted May 23, 2013 Author Report Share Posted May 23, 2013 Thanks Cara Link to comment Share on other sites More sharing options...
