Bazel27 Posted November 11, 2010 Report Share Posted November 11, 2010 Hi I’m trying to programJazz JZ-11-UA24 , and want to activate an analogoutput +10v from controller keypad. I have tried to store a value #8192 into the MI100 which is connected toanalog output, but it doesn’t take any effect. Can anyone show a programexample, for me ? Thanks Aleksei Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted November 14, 2010 MVP 2021 Report Share Posted November 14, 2010 Try value 8191, as well as other values and see what you get. I had an experience driving an IO-AO6 module (4096 counts) where I put 4096 in the controlling register and nothing happened. At 4095, it magically went to full output. Something to do with 0-based D/A. Joe T. Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted November 14, 2010 Report Share Posted November 14, 2010 Hi Aleksei, Please note that the output range is from -4095 to 4096, where -4095 yields -10v and 4096 yields 10v. Verify that you configured the hardware correctly. Check if you can store values from On-Line mode. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted November 15, 2010 MVP 2021 Report Share Posted November 15, 2010 Hi Aleksei, Please note that the output range is from -4095 to 4096, where -4095 yields -10v and 4096 yields 10v. Verify that you configured the hardware correctly. Check if you can store values from On-Line mode. I read the spec sheet on the JZ-11-UA24 before I replied and came to the same conclusion that Aleksei did. The documentation needs to say something like +/- 4095 = +/- 10V. I took the liberty of updating the pdf and attaching it to this post. The changes are on page 4. Please have Cara review it and put it on the website. By the way, what's this 500K global upload quota? When does it get reset? Joe T. JZ10-11-UA24_JZ10-11-UN20_TECH-SPEC.pdf Quote Link to comment Share on other sites More sharing options...
Bazel27 Posted November 16, 2010 Author Report Share Posted November 16, 2010 Thanks, alot. I have solved my problem. Thanks to all for replies. Aleksei Quote Link to comment Share on other sites More sharing options...
