gerard Posted November 30, 2013 Report Share Posted November 30, 2013 I have downloaded my program onto the V1040 and some of the images have come up blurred on the screen. I have attached screenshots in a pdf - has anybody every had this problem and, if so, what caused it? Fuzzy Screen.pdf Quote Link to comment Share on other sites More sharing options...
Saragani Posted December 1, 2013 Report Share Posted December 1, 2013 Can you supply the project? Do those pictures also appear to be drawn incorrectly in Visilogic? Thanks. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted December 1, 2013 MVP 2021 Report Share Posted December 1, 2013 I've had something similar happen on several occasions. The following procedure has fixed it for me: 1) Download a blank project to the PLC. 2) Initialize and Reset the PLC. 3) Download your project. It seems that somehow the memory space for the images can get corrupted. Downloading a blank project clears that out and then when you download your actual project all will be well. Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted December 2, 2013 Report Share Posted December 2, 2013 Hello, Such problem may related to project that has been written in older version then the current version (V9.5.0). I manage to download the project to my PLC and it looks OK. To solve the problem please refer to the steps below. Download the latest system files (O/S V3.7.0, BinLib, BOOT) via COM port RS232 115200 baud rate 1.5sec time out Download a blank application initialize & reset the PLC Open your project and restore the system images (click on system images icon left to the alarm configuration icon) Perform build all from "build" menu Download all & Burn i hope it helps... Quote Link to comment Share on other sites More sharing options...
