laporbr Posted January 29, 2015 Report Share Posted January 29, 2015 Hi there i am trying to initialise the enfora modem PLC side but he keeps on saying modem operation failed modem not initialised . i have done everiting according the manuals ? used the right cable deliverd with the modem . i am out of possibilitie's what to do ? What is there to try more , thanks for feedback enfora modem .pdf Link to comment Share on other sites More sharing options...
Eyal Koren Posted January 29, 2015 Report Share Posted January 29, 2015 Hi, Please check the following: 1. Check if the Sim Card is inserted correctly to the modem. 2. Is the sim card protected with a pin code? 3. Is the Sim card open for data communication (contact you cellular provider). 4. In Modem services, enter your cell phone number in the "Number to Dial" box. Then press "SMS Options". From the SMS Options window, enter some text in the "Send Message" box, and press "Send SMS message". you should receive the message in your cell phone. If you cannot receive the message, or getting a modem error message, please let me know. Link to comment Share on other sites More sharing options...
laporbr Posted January 29, 2015 Author Report Share Posted January 29, 2015 sim ok tested in modem wavecom , worked ok test in enfora met sim who i know is good , not working i have trie to initialise the modem by modem services visilogic seems to work but still not working to send sms status SB180 stays 0 ?? thanks for any further suggestions Link to comment Share on other sites More sharing options...
small7 Posted January 30, 2015 Report Share Posted January 30, 2015 Hi, i have the same problem. i tried all steps but it's not work. I cant initialize PLC modem. I tried step 4 but i have modem error. What is wrong? Link to comment Share on other sites More sharing options...
AlexUT Posted February 1, 2015 Report Share Posted February 1, 2015 Hi laporbr, Please do not use "Report this to a moderator" as a reply in topic, as nobody can see it . Next I will paste what you sent in "Report this to a moderator". ========================================================================== laporbr laporbrNewbie Members 3 posts 0 warning points Posted 29 January 2015 - 10:01 PM Eyal Koren, on 29 Jan 2015 - 4:25 PM, said: Hi, Please check the following: 1. Check if the Sim Card is inserted correctly to the modem. 2. Is the sim card protected with a pin code? 3. Is the Sim card open for data communication (contact you cellular provider). 4. In Modem services, enter your cell phone number in the "Number to Dial" box. Then press "SMS Options". From the SMS Options window, enter some text in the "Send Message" box, and press "Send SMS message". you should receive the message in your cell phone. If you cannot receive the message, or getting a modem error message, please let me know. Hi ,i have another modem Wavecom and i tried the sim card in this one . This modem is/ was allready initialised . With this modem it works perfect so it can't be the sim card .when i try to remove the phone nr in the number to dial i get runtime error 70 permission denied .any other suggestions ? Link to comment Share on other sites More sharing options...
AlexUT Posted February 1, 2015 Report Share Posted February 1, 2015 Hi, Please check if in Prepare you use 9600 bitrate. If you continue to have problem - send your project to suppport@unitronics.com for review. Sometime there are sadden errors in Ladder, modem settings, etc. BR. Link to comment Share on other sites More sharing options...
Eyal Koren Posted February 1, 2015 Report Share Posted February 1, 2015 Hi laporbr, Please do not use "Report this to a moderator" as a reply in topic, as nobody can see it . Next I will paste what you sent in "Report this to a moderator". ========================================================================== laporbr laporbrNewbie Members 3 posts 0 warning points Posted 29 January 2015 - 10:01 PM Eyal Koren, on 29 Jan 2015 - 4:25 PM, said: Hi ,i have another modem Wavecom and i tried the sim card in this one . This modem is/ was allready initialised . With this modem it works perfect so it can't be the sim card . when i try to remove the phone nr in the number to dial i get runtime error 70 permission denied . any other suggestions ? The permission denied error may point to bad dll registration issues. Please try to reinstall Visilogic with administrator privileges. To do that right click on the installation file, select properties and press the Unblock button. Then run the file as administrator. From the installation menu select Repair. Please let me know if that solved the problem Link to comment Share on other sites More sharing options...
laporbr Posted February 6, 2015 Author Report Share Posted February 6, 2015 Hello , i have even used a computer with windows xp where i have full administartive rights on it . I can initialise the enfora modem GSM1308 by using the modem services and then prepare plc side modem . It's starts running and doesn 't give any error or alarm . ( initialised with the cable deliverd with the modem ) . when i then connect it to the M90 with the standard program cable and the connector MJ10-22)CS72 and try to work with the plc programme 1 first initialise ( set bit SB180 and see if SB181 comes high . this is not happening ??? baudrate is set to 9600 remark : i use the identical software and the same Sim card in a wavecom modem and the it's working . in attachement the program ( line 40 is initialising the modem and line 41 is send test sms suggestions ? What should exactly be in the initialising commands ? this is what is standard in the field ( adjusted baudrate to 9600 ) i have also tried with hyperterminal but don't find a reason ? the bit SI 70 is showing value 2 AT&FWAIT 5GOBR 115200AT+CPIN=^XXXX^WAIT 3ATS0=1ATE0AT&C1AT&D0ATX4ATQ0ATV1AT+IPR=9600WAIT 5AT+IFC=0,0AT+CNMI=2,1,0,0,1AT&W Link to comment Share on other sites More sharing options...
Jordy Posted July 8, 2015 Report Share Posted July 8, 2015 Hi, i have exactly the same problem with an infora and vision130. on the pc it"s working perfect, but not with the PLC. i did all actions (prepare plc side modem, pin code, ...) correctly did you ever had a solution for this problem? Link to comment Share on other sites More sharing options...
AlexUT Posted July 12, 2015 Report Share Posted July 12, 2015 Hi vema, Please send description of your problem to support@unitronics.com. B.R. Link to comment Share on other sites More sharing options...
laporbr Posted July 13, 2015 Author Report Share Posted July 13, 2015 Hi Vema , sorry to say , i have tried so many things i do not remember any more what exactly made it working . So i can not give you any good feedback hope unitronics will give a feedback Link to comment Share on other sites More sharing options...
