kellys Posted November 10, 2015 Report Share Posted November 10, 2015 Is there any way to allow a user to change email server, username, password, etc within the HMI, without requiring the changes to be done in Unilogic? I have been using a gmail account, but whenever I'm forced to change a password online the PLC is no longer able to send emails without first making the changes in Unilogic and then updating the PLC. Ideally all of the email account settings including adding a new email account should be able to be configured within the HMI so that this would not be an issue. Also is there any way to remove the requirement for the outgoing Mail Server to end with ".com"? Lots of internal email relays do not end with a .com and this prevents their use. Another requirement that is limiting is the use of an email password. I understand these requirements are put in place to help prevent from someone making a mistake, but unfortunately this severly limits situations where these can't be used. Thanks! Quote Link to comment Share on other sites More sharing options...
kellys Posted January 25, 2016 Author Report Share Posted January 25, 2016 Anyone have any idea how to change email server, username, password, etc within the HMI, without requiring the changes to be done in Unilogic? Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 7, 2016 Report Share Posted February 7, 2016 Currently, it is not possible, but it's on our list. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted July 3, 2020 MVP 2021 Report Share Posted July 3, 2020 On 2/7/2016 at 1:02 AM, Saragani said: Currently, it is not possible, but it's on our list. Still on the list, @Saragani? Quote Link to comment Share on other sites More sharing options...
Saragani Posted July 6, 2020 Report Share Posted July 6, 2020 This is actually being done differently. Since version 1.25, there is a Ladder Element called Load Config - .ini from SD It allows creating an INI file with multiple settings, which let you config email accounts, FTP Client and server, IP Settings of the Panel, etc. Then the config stored in the SD, and loaded to PLC. This is done in order to allow changing a lot of settings in one shot, allow configuring PLCs 1 after the other by placing the SD card in them and loading the file (or storing the ini file in the SD by any other mean, like FTP), and then loading it, and it is also suitable for PLCs without Panel (Like the USC models). From help file (LF: SD File Functions) File Syntax Example Note that file begins with version 100. [Version=100] [EMAIL_ACCOUNTS:Account1] UserName=fyodordostoyevsky [EMAIL_ACCOUNTS:Account1] OutgoingServerSettings=fedya.man.dd:1 [FTP_CLIENT:FTP Client1] UserName=PrinceMyshkin [FTP_CLIENT:FTP Client1] Password=lee1987WWWnEW1 [FTP_CLIENT:dimanewclient] Password=lee1987WWW [FTP_CLIENT:dimarnewclient] Port=1212 [FTP_CLIENT:dimanewclient] RemoteIp=10.1.30.252 [FTP_SERVER:FTP Server1] Password=fF1s3New1 [FTP_SERVER:FTP Server1] Port=23 Function Editable Parameters Email Accounts User Name, Password, Outgoing Server Settings, From FTP Client User Name, Password, Port, Remote IP FTP Server User Name, Password, Port, Read Only FTP RAM Server User Name, Password, Port Network Panel IP Address, Subnet Mask, Default Gateway COM Modbus Baud Rate, Data Bit, Parity Bit, Stop Bit Legal values: BaudRate values: 1200/2400/4800/9600/19200/38400/57600/115200 DataBit values:8/7/6/5 ParityBit values: N,E,O StopBit values: 1,2 Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted July 6, 2020 MVP 2021 Report Share Posted July 6, 2020 1 hour ago, Saragani said: This is actually being done differently. Thanks, @Saragani. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted July 6, 2020 MVP 2021 Report Share Posted July 6, 2020 Now THAT is handy. Thanks for bringing it to our attention! Joe T. Quote Link to comment Share on other sites More sharing options...
